Shocking accident on the gird in Perth when Kerl Reindler stalled and was hit heavily from behind.
All the best to Karl, hopes the burns aren't too bad
REINDLER IN HOSPITAL AFTER HORROR CRASH
Karl Reindler has been transferred to hospital after an horrific start-line accident that saw his car engulfed in a ball of fire at Barbagallo this morning.
The Fair Dinkum Sheds Racing driver received superficial burns to his hands and face and smoke inhalation.
V8 Supercar Chief Medical Officer Carl Le was first on the scene and Reindler received the best medical care.
The accident happened when Steve Owen ran into Reindler, who was stationery on the grid. The car burst into flames but Reindler reacted quickly, leaping out of the car.
Karl Reindler
“I loaded the clutch up and it stalled. I had my foot all the way down; I didn’t even release the clutch. I couldn’t get it going at all. There’s nothing I could do.
“Before I knew it I saw flames inside the car. I guess I panicked and tried to get out as quick as I could. My body’s fine, it’s just my hands.”
Dr Carl Le
V8 Supercar Resident Medic
“Karl has suffered some superficial burns to his hands and face and smoke inhalation. He has been transported to hospital, but he is OK.”
Steve Own
Paul Morris Motorsport
“It happened that quick I barely got on the brake by the time I hit him. I was in third gear, flat out after getting a pretty good start.
“I opened both doors and there was fire there. The officials did a great job. Without them putting the fire out I wouldn’t have gotten out of the car.
“I felt pretty sore when I first got out of the car but I’m alright now. I saw Karl briefly in the medical centre and fortunately he’s fine apart from some light burns. ”
https://www.sau.com.au/forums/topic/362706-perth-v8-accident/
nasty....I counted about 12 seconds to get out of the car after it stopped moving, so make it 15 all up. he forgot to take the window net out first time, and forgot to unplug intercom too.
no criticism, just a reminder how hard simple things can be when you are in major shock. there aren't many worse crashes than that, thank god he wasn't knocked out.
yep thats hell scary.
i was talking to a mate about what the saftey backlash of this will be. that said it has happened a few times before.
he recconed they would bring in rolling starts. all i had to say to that was More NASCAR
+1 nascar would be way more interesting to watch on aussie tracks than the sequential cheatbox taxis.
the less modern technology the better, leaving more margin for driver error and the resulting overtaking.
bigger, heavier, carb'd 4 speed manually shifted tanks. awwyea
Edited by scooby36
+1 nascar would be way more interesting to watch on aussie tracks than the sequential cheatbox taxis !
the less modern technology the better (apart from safety)
bigger, heavier, carb'd 4 speed manually shifted tanks. f**kyea!
So you mean Sport Sedans yeah......wut?
This happens in many categories, I think drivers need to have a button on the steering wheel that will set off an alarm in the starters tower and trackside led lights if they stall on the grid.
As it happened live I thought wtf is that board the starter is holding out, the 5 second board? but the lights are green, then it was just a fireball, so the marshalls were all onto it but the drivers have tunnel vision at that point in time.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
