  • Replies 57
Posted Images
It's funny how nothing seems easy on the M35. Maybe we should be all driving C34's :laugh: .
I'm now considering this a challenge and will pursue it to it's completion, be it successful or not. With knowledge comes (power?) the ability to find solutions to other needs/wants/problems that may crop up in the future, plus I love to learn.
It has also occured to me that if I have the ability to open the throttle a little more at say 20% (where I sit most of the time on the freeway) it will make the engine more efficient. If, as a byproduct of this, it reduces the injector pulse width with no or little change to cam timing I could have a sweet spot set up for a lean cruise mode. The point being, even if I'm not 100% successful in beating the throttle restriction above 80%, there could be an indirect benefit of this R & D work.
I like the way you think -outside the box. I'm not sure if that is a viable solution but I will ponder the implications & anything else related that comes to mind during the week. It seems that almost everything in our factory ECUs are tied to something else. Thanks for your input Steve. Oh, and max throttle I've ever experienced according to the informeter is 85% I think. In the last couple of weeks it's been nothing over 80%. Again, it's so many other factors which determine what the ECU allows you to do.:mad:
As for you other guys - you crack me up :rofl: It doesn't take long to degrade into a free-for-all lol.
here is something to add to the many curve ball's....the throttle stepping and open% may also be changed buy the temp sender on the AFM!.....density of air and all that crap.....I hope you crack this one Leon. Another thought as our ECU is similar to the AT RX8 in the way it control's everything maybe there might be some info on this within the RX-8 forums somewhere!
anyway just my thought's and awesome work Leon!...don't you just love drive by wire!
I think you are spot on and there may well be a couple of other parameters thrown in for good measure! If I had to determine exactly what the ECU looked at to open the throttle a given amount, I'd need a lookup table far bigger & complex than I'd be able to put together myself with the resources I have.
I'm guessing now, but at this early stage I think I'd be lucky to get maybe an extra 10% total opening consistently. Another few % may come with the other parameters that will be outside of my control.
I'll just sneak up on it tho. I little research, a bit of measuring, a LOT of trial & error & see what eventuates. And no, I don't particularly love DBW :glare: .
give me a full ecu wiring diagram in english and ill sus out whats holding it back from opening up the throttle....... ie: all sensors attatched to the ecu etc etc
Wiring diagram.. as in which pins do what? we've gone one of them thats fairly complete, and I should be able to do the rest if theyre required? :)
actually a diagram wont help with out the software to be able to access the ECU to see the program that is running.
the wiring diagram will only show whats connected to the ECU and not how the ECU uses the information.......... i was thinking to symplistically HAHA
has anyone spoken to these guys.......... http://www.nistune.com/index.php
edit*** is this the correct ecu for our cars? http://cgi.ebay.com.au/NISSAN-STAGEA-M35-ENGINE-ECU-/270745912798
Edited by WAGON_BOY
Well I have a Stagea VQ30 ecu for $100 if anyone wants it. Someone on this site said that the VQ30 did not have fly by wire throttle so should be ideal for someone who wants to try a mechanical throttle. Its off a n/a engine so ideally would be run with a piggyback and standalone ebc.
How are the cam's controlled on a VQ30? Does the VQ30 ecu talk to the gearbox? What sort of gearbox does the VQ30 have? List goes on.......if only it was that easy! Thanks for the offer and nice thinking!
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
