  • Replies 149
Slightly off topic but kinda still on...
What do you guys use as far as the rest of the fluids? My M35 will be here soon and I plan on giving it a big service so I know where I'm at but just looking for advise as to what peopl run... Engine/Trans/Diff/Altessa?
Much thanks :)
Engine: Neo N-RPS-10w30 – 5L
GB: Nissan Matic-J or S
Altessa and Power steering: Nissan Matic-D
Diff: Neo Diff oil.....or the good Castrol stuff (If you have V-Hicas you will have a limited slip diff....make sure you use the correct LSD oil)
I do indeed have a V-Hicas, can I assume only the rear diff is an LSD? so 2 different oils will be required?
Also what is the transfer case Aaron spoke about? :)
the transfer case hangs off the Transmission and you'll see the front drive shaft going into it. It holds the clutch plates for the trans
its about half a litre of oil and doesnt take more than 20 minutes...
im using Red line Light weight shock proof for my rear LSD. some people dont like it. but it says its made for LSD as well, and I havnt had any problems at all. and its a group 5 oil. ive got it in the front diff too
Much thanks :)
Take a look at www.m35stagea.info in particular the thread below will have your answers.
http://m35stagea.info/forum/viewtopic.php?f=2&t=67
You sure its the same filters as S15? GCC listing says its the same as a SR20DE, but theres a different filter listed for SR20DET?
SR20DE: http://www.gccorp.com.au/automotive/product_info.php?cPath=54_57&products_id=145
SR20DET: http://www.gccorp.com.au/automotive/product_info.php?cPath=54_57&products_id=144
I'm running the SR20DE at the moment.
If you are running the Nismo oil filter, it should state on the side of the box that it is used for M35 and S15 among others.
The engine list from your link
Avenir W10 SR18DE, SR20DE (94/11 - 98/08), W11 QG18DE, SR20DE(T), QR20DE (98/08 -)
Wingroad / AD VAN Y11 QG13DE, QG15DE, QG18DE(N), SR20VE, QR20DE (99/05 -)
Xtrail T30 QR20DE, SR20VET (00/10 -)
Elgrand E50 VQ35DE (00/09 - 02/05), E51 VQ35DE (02/05 -)
Sunny B15 QG13DE, QG15DE, SR16VE, QG18DD (98/10 -)
Cima F50 VQ30DET (01/01 -)
Silvia/200sx S14 SR20DE(T) (93/10 - 98/12), S15 SR20DE(T) (99/01- 02/08)
Skyline V35 VQ25DD, VQ30DD, VQ35DE (01/06 - )
Stagea (including 260RS) the M35 VQ25DD, VQ25DET, VQ30DD (00/10 -)
CEDRIC/Gloria Y34 VQ20DE, VQ25DD, VQ30DD, VQ30DET (00/08 - )
Teana/Maxima J31 QR25DE, VQ23DE, VQ35DE (03/02 -)
Pulsar N15 SR16VE, SR18DE, SR20DE (95/01 - )
Fairlady/350Z Z33 VQ35DE (02/07 - )
Primera P10 SR18DE, SR20DE (94/09 - 95/08
Primera P11 QG18DE, QG18DD, SR18DE, SR20DE, SR20VE (97/09 - 01/01), (W) P12 QG18DE, QR20DE, QR25DD, SR20VE (01/01 - )
Seems you answered your own question??
Now I'm more confused... they both say SR20DET, just different models. Surely one SR20DET is the same as another? :s
Doesn't matter, my oil filter is right, so I'm all good! :thumbsup:
if they'd revised the sump design between the S14 and S15 they may have needed to use a different sized filter ;)
close, S14 and S15 engines are almost identical. the S13 and S13 FWD SR20 took different (and larger) filters.
i think i am going to go with
Castrol SLX Professional
Longlife III
Powerflow 5W-30
Its what my VW use on all their Golfs including the GTI and on all modern Audi's now too.. One oil is nice for both cars too means i can always use the excess :)
Edited by Sage222
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
