  • Replies 149
Yeah, was referring to the stock ecu.
The emanage will modify an existing signal (x +/-) so if/when the stock ECU changes it's tune, you'd see a change in the overall tune.
yeh thats true.. but i guess its something we could probably never confirm..
Scott: is there a pinout for oil pressure?? or of the similar perhaps?
oh yeh i know that, i thought initially he was talking about the emanage having inputs.
after speaking to craig i think my problem is the fuel pump.
seeing as i bought it off the same person, i come to the assumption that they are fake.
Failing fuel pump = Less Fuel = Higher AFR? Makes sense to me.
Was it an ebay store you guys bought through?
yeh it was.. scott laughed at me when i told him lol.
I have a shop that sells them locally for $130, and are a genuine Walbro Disto.. so will definitely go and get one once i test it with scottys spare tomei one..
FWIW, craig explained what happens when his would die. and its exactly what mines doing..fuel pump may have just coincidentally shit itself while i did the oil.
come to think of it, the car was stuttering on idle the night before after a spirited drive..
thanks everyone
lol... perhaps something you could have told us earlier?
didnt think it was necesary. my when it did this my AFR's were showing 10. 10 being the minimum of my gage so it could well have been richer
so i found it wasnt the fuel pump, wasted $130 on a original walbro...
Cihan had a look at the tune and was confused as it had gone all over the place..
i explained that i fixed an oil isue(in detail)..
he retuned it back to AFR's of 11 on WOT.
a f**kING noticable difference from the last tune which was at 285kw.. now at full throttle in the dry i loose traction at the end of first gear..with the pirellis.
so ive made a significant gain of power.. also my boost issue has gone away and is now sitting at a comfortable 20 psi right through the rev range.. however ill still be getting a larger wastegate and running it..
he also said im close to 80% of injectors lol
im one happy camper today.. f**king glad somethings gone right for a change
Youve neglected to tell us what the new number is :P
i dunoo it was a road tune..
he guestimates from last time that its definitely above 300awkw.. only to get more once i change the wastegate lol
it has to be over that as a 15 kw difference isnt this noticable at all
Haha, never happy are you mate. :whistling:
The general consensus is more boost not less. What are you worried about? :ninja:
coming from the guy whos putting a GTX in his Stagea.
hey if i can open up that wastegate, and run the power that i have now, at lower boost, i'll be happy!
honestly if i find that ill make over 300.. i'll ask him to de tune it back to 300awkw i actually dont want to run more than that, as its probably close to shitting the internals.. honestly you need to take it for a drive today its fkn different to the last tune..
Engine? Doubtful.
Transmission? Maybe (I still reckon the stock box with a shift kit will handle it)
  • 1 year later...
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
