yeah I have used AD07s and AD08s as street tyres and for outright grip they are not great. good streeties but not so good on track. the BEST street tyres i've used for track use are dunlop Z1 star spec. I ran them the other day at wakefield and ran a 1:12 in my little emo with just 200kw and pezzy non-brembo brakes (and my limited driving skill). I was shocked how much grip they had, very predictable too. they do like more pressure in them than semis which can throw people off a bit at first.
if your car is 90% street with the odd track day then I'd probably use the Z1. if you are more focussed on getting good times and rarely drive on the street then for sure semis are the go. even the Z1s wouldn't be as fast as a used semi in reasonable shape (but not miles off either).
anyway for your budget really your only option is used tyres. so just hang out for some cheap thrashed semis and enjoy. :)
  • Replies 47
Sounds like semis for me then. Car gets driving on the street maybe 10 times a year? And for that I have some cheapo 17s with cheapo rubber.
Someone give me the hook up on some used semis, I know a few tyre shops have them but I'm having no luck.
Mine is quicker on worn out semis with chord hangin out of them than the KU.
KU is good, don't get me wrong, but it's still a streeter.
yeah, but you've never used the R888 semis. Worst semi I've ever used by a long way!
I went from KU36 to R888 and the only advantage was a bit of corner exit traction. I doubt they have any more lateral grip than the KU36.
Having driven on both, I would buy the KU36 over the R888s any day of the week.
Edited by hrd-hr30
That's interesting stuff Harry. I think temp hs a bit to do with it, from what I read KUs hold there own on really cold days when the semis can't get up to operating temp.
Is this your experience? As it seems you're in the minority on whether KUs are as quick as new or old semis.
FYI I've been looking for some more RE55s
Same as me then, basic coil overs and a couple adjustable arms.
The shagged RE55s still seemed to have a ton of grip to me, more grip than my talent (or lack there of) could make use of without feeling like I was hurting the car so I'll hold out for some more semis.
If you guys come across something let me know.
Its not that KU's are as quick as new semis, its more that R888's are as slow as KU's.
RE55s will blow KU36's away. R888 won't. That's been my experience anyway.
3 May 09. Lakeside 1:00.79
nearly worn out KU36 on a big fat 1540kg JZA80 Supra. Stock turbos & boost. 186rwkw. Stock suspension apart from Tein Flex.
vs
19 April 09. Lakeside 1:00.32
brand new R888 GG on a stripped out Sil80 which would have been at least 400kg lighter. 200rwkw.
I replaced the R888's with Federal FZ201 nov last year. The difference is night and day. Haven't run them at Lakeside yet so can't compare times, but these feel very grippy like all the semis I've used before - RE55S, Toyo RA1 and Yoko A032R. Its what I was expecting when I bought the R888s a couple of years ago.
R888's get up to temp really quickly, that wasn't the issue.
I wasn't overly thrilled with mine either but eventually found how to make the most out of them. In my case, lots of camber and fairly low pressures (low 30's hot). Even then outright grip was still less than i have now with the same alignment and re55s running a little more pressure.
Keep in mind that the FZ's are only available in medium at the moment
Edited by badhairdave
Anyone heard of/used these?
http://www.viczcar.com/forum/index.php?topic=9207.0
Proper details
http://www.silverstone.com.my/default.aspx#1305179110073
Are these a proper R comp?
Edited by ActionDan
Why not just use the KUs which are cheaper than used semis in terms if $ for tyre life?
Do more trackdays to improve driving skillz rather than trying to buy your way into faster times?
Its more a case of knowing that semis have more grip than I can skillfully use.
With the Ku's I don't wind to wind up with a tyre I feel can't keep up which will frustrate me as I'm already used to the grip of semis
I still reckon KU's a pretty good thing. I'm astounded with how well mine have worn given the pizzling they copped. Two tray days and with the exception of a flat spot for all intents and purposes look new.
Maybe I'm just becoming a pussy in my old age? :)
I'm with you Ben. I remember my KU36's still had the writing visible in the middle of the tread surface after the first track day. And no-one's ever accussed me of being gentle on tyres.
I've had a good run with KU's at DECA on skidpan etc. won my first outright DECA on KU's that were only a day old. I wouldn't use them for sprints as I enjoy driving with semi's so much more but I still managed a 38.4 on KU's at winton last year.
I reckon you should buy these. A bit old and they might happen to be my old ones :whistling: but they will be good and they're cheap!
http://www.skylinesaustralia.com/forums/topic/352790-4x-semi-slicks-225235-17s/page__p__5655391
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
