  • Replies 83
Payment details please too. :)
Hey guy's,
I have been away for 1 1/2 weeks, limited internet access in NZ
I will PM my account details today to all once I get on top of my work back log.
Thanks
1. Style - Gias 2 Low max recliners
2. Back materail - frp
3. Materail Colour - black
4. Pick up Brisbane or Post - Post to 3032
Can you send me your bank details please
Paid and cleared funds
Thanks for fast payment
1. Neil_se
2. R33_racer
3. DKBcleaner
4. 32_Dave
5. DILf*kin
6. Sugz
7. FFRACER
Edited by darrinspencer
Just sent a Pm to last few who have not paid yet to see if they are in or out.
1. Neil_se
2. R33_racer
3. DKBcleaner
4. 32_Dave
5. DILf*kin
6. Sugz
7. FFRACER
8. Wlspn
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
