great little track, very relaxed attitude from most people when i was there last.
31sc is having a day on the monday Prior so im just deciding what day to come along, hmmmmmm.
You know a bunch of SAU:NSW Skyline's (And other cars) buzzing round will be just awesome and beat any other day, right?... ;)
  • Replies 106
good to see the entries coming in....we need to fill this so we can keep running these types of events.
It is almost impossible to book Wakefield, and Eastern Creek want $20k a day (so, we would have to charge about $500 per entrant). Places like MDTC can give us a cheap way to scratch the track itch :D
Scott, we will find out and confirm. If you are looking at doing a few track days there are IR based lap timers like AIM that mean you can get times at any event.
Scott, I use a GPS laptimer. You have to download the data to a laptop, but it is very accurate and better yet you can divide the track into sections to see where you gain or lose time. Well worth the $200 if you are trying to learn what you are doing right and what needs improvement.
Mine is the QStarz version which can be found locally and on ebay.
Entering today hopefully!! :)
Just been wondering, I've got a 3" Kakimoto catback on my gtt which is said to be road legal, I'm looking at upgrading to turbo back, would that make it unable to run?? Does anyone know??
You should be fine sound wise mate.
ok cool. i just looked on the form and it says type of license and the number, i dont have my cams yet, do i need to get that first?? and also i still havent been given my membership number, shell said i can have a mock number if i need it. so can i just write, havent received number yet??
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
