Oh dear, looksee what has happened now.... We may have lost one of our brightest, consistent and most informative poster's ever !
Damn you, Damn you all
I needed to know so much more..... and now..... i never will
*sigh*
Please come back UNDR8ED; all is forgiven.
Please share your boundless knowledge of how to use unnecessary capitalisation and numerals within words to convey your vast wisdom; we are lost, and have much to learn.
Edited by Daleo
I can't even pronounce his name without help.
Is he under bed ? Thats just plain weird man !
Damn it .....I was wondering if he was ever going to inform us the the m35 doesn't have an RB! :P
Seriously what a f{:content:}amp;ktard!
FARKEN WHAT!?!?!? thats the reason i bought a Stagea for all the plentifull and cheep RB goodies to bolt on :( damnit should've bought a skyline!!!
My GTX3071 made 288rwkw on 98 at 21psi im now on E85 and at 18psi made 307rwkw and on 22psi with major boost leaks got up to 312kw with predictions of theoretical possibility of 350rwkw.
GTX3076 some boys are making 360-400rwkw on E85
so whats the figures on these???
GTX3071.......... is that the stage 1 hiflow option? 270kw max?
GTX3076.......... and this is the stage 2 hiflow ? 270kw+ ?
is that on a VQ25DET with 4WD ? otherwise those figures are kinda pointless...........
altho a HP figure on the crank would be useful :)
I have your GTX3071 at 278.5 as tuned with 98ron. It is a bigger jump with the E85 than you are quoting. Keep in mind my old school GT3076 with ATP TS housing seemed to come on earlier than the smaller 71mm GTX with 98ron.
The claims of 360-400rwkw with E85 might be coming from a certain dyno which seems to produce some higher results than many others so make sure you compare apples with apples. Early results show the GTX3076 to be very similar to a GT3082 aka GT3040. The turbine has proven to be the limiting factor on these turbos.
Scotty has the bigger Tial housing (from memory) so the 76mm GTX compressor will have every chance but ultimately I reckon the 71mm compressor is not the limitation.
It peaked at 288kw but was bought down to a "safe" 278kw :whistling:
Dyno figures for the GTX3076 are in the RB25 dyno thread dont know what dyno was used simply requoting figures
You love bringing up that the ole 3076 comes on sooner than the GTX dont ya mate lol :nyaanyaa:
I'm guessing the current gtx3071 is good for around 320 on ethanol, on an m35, hopefully the 76 can add 30 to that figure so around 350awkw, perhaps a little less with the .82 rear on it. That's the next goal anyway.
Not sure the box will be happy with that figure, even the 33gtr box I hope to slip in may not handle it for long.
These are not highflow turbos, they are large housing surge ported Garrett turbo's with external gating, much more chance of a higher figure.
Will the GTR box drop straight in scotty or will it need mods? Has anyone ever looked into or tried Cryotech for gearbox parts dont know the exact process but they use liquid nitrogen and put them under vacuum i believe and claim that it hardens things by 300% NASA stumbled on it when all the space shuttles returned harder than were originally made? I recall seeing its around $60 a kg or something would be a cheap alternative for a hardened GTR gearbox if the claims are true :blush:
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
