Good luck mate what sorta time you aiming for ? 12.? :nyaanyaa:
Yeh Mick, very close power wise.
The car still doesn't feel that quick, its a fair bit heavier than a skyline but the torque obviously helps. I guess I will see what it can do on Friday. :)
i don't finish work in the eastern burbs till 5.30
but there is a few of us planing to come in for a geez, spose we will be there round 7-7.30
ill bring my camera for ya.
Great, see you there. :thumbsup:
At least this time someone will know what a Stagea is. Lol.
I did 13.5 with 240kw, a low down throttle restriction and speed cut by 3/4 track. Hoping for a high 11 this time out but I doubt it due to the weight and RWD.
Haven't got the front diff in?
What have you been doing all day!? Should have time tomorrow morning, yes?
11's will be nice......Good luck and may the boost be with you :thumbsup:
I will be watching this spot for a time slip closely :ninja:
No point waiting, I couldn't get the thing to launch at all. Nearly 3 seconds for a 60 foot is a joke. The 1.06 has to go, time for the .63 rear perhaps?
I had overheating issues also, not just the water and trans fluids but the fuel was boiling too. It would just bog down and missfire off the line.
The trap speed was pretty good, 112mph (180kph).
I was definitely reeling the other cars in but they had me by 3 car lengths out of the hole.
Just tossing up between the .82 and the .63 rear housings as every other way around the problem involves making the car less drivable on the street. (other than going 3.5L :whistling: ) I really don't want to go to a 4k stall converter.
so what was the 1/4 time? 0-100?
Wonder why it didn't launch well. Your old setup did ok didn't it?
You mean yours? :)
The turbo only makes 2 psi at stall and thats after holding my foot flat for a few seconds. Then it just bogs down. I need it to wheelspin off the line to have a chance hence I need the turbo to make full boost (or close to it) by 3k to match the stall converter. I knew this all along but I wanted to see what the 1.06 was capable of.
I ended up with a 13.9 but was going 141.3kph by 1/8th mile after the 2.8 second 60 foot. Only one timeslip as the tards lost the first one somehow. Thats .4sec worse than the last run, back on the highflow with 250kw, speed cut and throttle restriction. Power doesn't make it quicker unless you can launch it unfortunately.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
