hahaha NO f**k that shit. What you can see a hint of on my ribs there is the name, date of birth, and date of death (if they've passed) for each of my 5 family dogs I've had through my life. Decorating the 5 lines of text is a bit of a generic/cliche rose bush/vine design that extends from the bottom line of text on my side, over my back, all the way up to my right shoulder. On my right shoulderblade I have another 2 lines of text, which are lines from a song.
Keep your shirt on for the next 6 months.
problem solved.
General idea lol. I'm gonna reduce calories by a little bit shortly since I really am over eating, but otherwise f**k it lol
Good progress dude.
What mutt have you got at the moment? Got a post up in the wasteland thread?
I've had 2 blue healers and 1 red healer (all passed), and currently we have another 2 blue healers. I haven't posted up any pics in that thread as I don't have any decent ones right now :( will have to harass my mum for some haha
  • 3 weeks later...
Shameless bump with some updates.
Lift progressions:
Bench press - 100kg 4 sets of 5 reps
Weighted dips - +50kg 4 sets of 8/7/6/5 reps
Incline DB press - 36kg 5 sets of 9/8/7/7/5 reps
Incline leg press - 380kg 1 set of 6 reps
I've started to get over the seefood bulk diet, there's not enough structure in the macros allowing for a little bit more fat gain than I'd really like...that, and I'm actually starting to bore myself of food hahaha. As a result, I've decided to cut back for a few weeks to regain some definition, then get back onto a MEASURED calorie surplus for a more steady gain for a while. Top pic is obviously one from before, second pic is one from this arvo after my first day of a harsh carb cut (compared to recent intake at least) as a reference for a starting point of this cut period. Top pic makes me look much more muscular and vascular thanks to the ludicrous amounts of carbs I was taking in haha...plus it was taken while getting changed in the gym (after back+bicep session).
Progress pic time....hate how taking a photo from waist height makes chest+shoulders look narrower than they really are :( oh well lol
hahaha cheers :D I can't wait til I can have my very first pic from the first post in this thread alongside my "final result" pic I'll be taking at the beginning of summer. Gonna blow my mind in the best way possible!
Even now I don't recognise myself rofl
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
