Next round up already, this one should sell out fairly quick.
Entry
https://secure1.ilisys.com.au/wrxc/motorsports/Introduction.php
Sub Regs
https://secure1.ilisys.com.au/wrxc/motorsports/Current_Supp_Regs.pdf
Entry list
http://www.wrx.com.au/forum/viewtopic.php?f=23&t=70436
Requirements
CAMS L2S
CAMS club membership with current date (SAU VIC Membership)
Fire Extinguisher
Two bonnet latching mechs (the standard double latch is ok, but for older cars with the single latch no good you need a second with a tie down strap)
Blue battery triangle 150mm x 150mm x 150mm (get yourself some blue contact from the news agency and cut one up!)
See you there.
2011 SAU VIC Motorsport Championship proudly sponsored by:
  • Replies 140
The Sandown round just gone, we have been warned. You will need two bolts restraining your fire extinguisher. So please make sure if you are coming along to PI that you have this done!
From what I saw at PIARC day on saturday, you just grab a garage and they come and find you. That's what the lady at check in said. We actually didn't get one coz it was a nice day...
So, if I mount it in the same way as ant1997 did, behind the drivers seat, using a larger base plate that is secured to the car with a single large bolt that holds the back seat cushion - and then use 2 bolts to secure the extinguishers bracket to this base plate - is that ok or not?
I wouldn't chance it, depends on what the scrutineer feels like on the day.
21 entries already. Get yours in fast!
Phillip Island is a reasonably forgiving track, more so than Sandown. So if your are thinking of getting involved, this is a good one.
From the supp regs....
b) Must be fitted with a fire extinguisher securely mounted on a metal bracket with metal straps Check - my fire ext came with a metal bracket and two metal straps within the cabin and readily accessible to the driver whilst still in the seat belt or harness Check - I've strapped myself in and can readily get the ext. and which complies with AS 1841 (save that extinguishers which meet AS 1841.2 are not permitted), and be of
at least 900gms capacity. Halon/BCF extinguishers are not permitted. The extinguisher and the bracket must be a compatible set, (i.e. as supplied by the manufacture of the extinguisher.)Check The extinguisher should be retained within the bracket by at least one (1) metal strap Check. The bracket should be secured using a minimum of 2, Grade 6 or greater bolts, of a minimum 6mm diameter, and self -
locking nuts Check - the fire ext bracket is mounted to the car using 2 bolts of a suitable grade. A suitably sized body washer may be required to provide extra support for the bracket. The securing system must be able to withstand a 25g deceleration.
Look as far as I am concerned the ext is mounted as per the supp regs. Tech the plate that the bracket is mounted on is part of the car. The plate isn't 1mm sheet metal, its a 5mm thick lump of steel securely attached to the car. Under 25g I'd be far more concerned about the metal bracket holding onto the fire ext than the plate mount coming away or deforming from its position.
my fire extinguisher is bolted through the floor directly beneath my legs in front of the seat. I had to use it recently and i wouldn't want to go grabbing it from behind the seat in a hurry.
Wow...so what you are saying is that your harness (if you have one in the S15, I can't remember) is so loose that you are able to bend forward in order to retrive the fire ext from the floor in between your legs? Remeber tech the rule states: Must be fitted with a fire extinguisher securely mounted on a metal bracket with metal straps within the cabin and readily accessible to the driver whilst still in the seat belt or harness
Like most rules in motorsport reg's the interpretation of the rule by two different people can vary. I would look at the postion where you have mounted the ext as being not accessible by the driver when still tight in the harness whereas I can still reach mine (I know I tested it).
What you have highlighted in bold is a bullshit regulation, it's unrealistic. I've never had an issue with scrutineering where mine is mounted. I don't know about you Ant, but when I'm properly strapped in to my harness I can barley turn my torso, let alone reach anywhere for a fire extinguisher.. and I wouldn't be staying strapped in the harness if the car is on fire.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
