I recently bought a HKS dump-pipe.
The pipe has no heat shielding, and I am concerned that the radiated heat will have an impact on hoses and
the engine bay in general.
Any suggestions how to control this?
Is this exhaust wrap (cloth) any good?
Personally I don't like the looks of it but can not think of an alternative ..
Any suggestions?
Thanks ... :)
https://www.sau.com.au/forums/topic/370896-heat-wrap-foil-what-works/
Wrapping works well to keep the heat in the pipe and not in the bay, but it can lead to the pipe corroding and/or cracking. This depends on the material used, how well it is welded and braced/loaded etc. The corrosion can be due to the wrap gettign wet then staying wet (doesn't happen often because usually when it gets wet it's hot because you're driving.)
By far a better option is to get it coated by HPC or equivalent. If you do this on the outside, then the metal of the dump will run hotter so you can sometimes get some of the same failures that you see with wrapping, but perhaps less often. If possible, then getting coating on the inside also helps to keep the heat from actually transferring to the metal of the dump, which is doubly good. Not easy to do and not guaranteed to stay coated either, under the horrible conditions found in there.
Your other option is to use some ACL heat shield material or bend up some stainless sheet and mount heat shields in such a way that they lie between the hot dump and anything you don't want cooked. Best not to mount the shields off the dump itself. Best to mount them off other locations. The OEM heat shields are of course all attached direct to the manifold/turbo/dump and the attachment points transfer heat to the shield, but they're still better than nothing, so if you get desperate you can use a stainless hoseclamp or two to hang shields off the dump.
I didnt find my exhaust had any affect on under bonnet temps at all. Maybe if you are sitting still, idling for a long time then it will get hot. But otherwise the air flow while you are driving keeps things pretty cool.
Hi there,
Thanks for the replies and ideas ..
I will work something out, but even if the heat is transported away while driving there will
be heat soak when you park the car.
The car is also moved in the city and in London you are stuck alot in ridiculous traffic :(
(though I try to avoid this)
Exhaust wrap works a treat...don't worry too much about so called cracking and corrosion and what not...its not going to disintegrate in a week...the hks dump pipes are made very well and will outlast the car most likely...
Wrap it, if it cracks in a coulpe of years get a new one and wrap that, also efective tape/shielding on local parts works for me.
Wet it first and wear gloves and long sleeves, that s hit is itchy.
Hi!
Yes, the HKS is stainless steel .. I wanted to have something which outlasts the car ;)
It's a nice piece of hardware but the location of the lambda-sensor is awkward ..
I will try the wrap (since it seems to be easy to apply and is also not expensive)
Many thanks ....
Snice we're on the topic.....
I have a aftermarket matched length dump pipe for the twins that pass very close to the gearbox and I was thinking about wrapping it to avoid heating up the box.
What i want to know is should I wrap just this one pipe alone, or should I wrap the both to keep the temp similar in both and therfore velocity? and all that simmidimmi ?
wrap both, put a shield on the gearbox itself.
Ceramic coating is awesome and cost roughly the same as good quality heat wrap. The shop near me does ceramic coating for dump pipes for $100.
Skylines do run quite cool compared to some other cars. My uncles R8(modded a little) runs quite warm you can feel it.
My brothers car had a tissue touching the dump.... It caught fire.... Its a rotor. It was quite funny, we were like what the f**k is all this smoke. Then you see a tissue smouldering. To note, the car was not driven, just idling in the drive way for about 3 minutes.
My input is it does make a difference. Ive sat passenger in my both my skylines a couple times. My old skyline was heat wrapped the whole way to the muffler(overkill?). This one is only wrapped on the cat back. I can tell you there is a definite difference in passenger footwell temps esp on longer drives.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
    • Nice shot! They look super clean. The roof rack delete on the black one is interesting. Would like to see more pictures from different angles. It's subtle but could make quite a difference to how the car looks in profile.
