  • Replies 244
Posted Images
Are there any restrictions on filling up from drums of fuel at Deca? This is my first outing since converting the car to E85 and not being able to duck out the to the BP for Ultimate out of the pump, so I just want to make sure I don't break some rule if I need to crack a drum open to fill up.
There is no problem with bringing up fuel.
Many people do it.
Pretty securely might not be enough mate.
When I've been doing it, people that have them drilled into the backing MDF where the battery is - get knocked back.
Simply because 99% of them I've been able to move the MDF by hand. Imagine a heavy amp doing the rounds should you end up in a spot of bother. Simply not worth a risk.
Advice taken onboard. They wiggled when I tested last night.... so it was a very quiet drive to work this morning >_<
Good to )hear( lol
But safety first mate, I'm gonna be helping doing scruitneering too in the morning it looks like, so glad that was covered off before the day.
I'll be emptying my car on the Fri night @ accomm, saves SOOO much stuffing around in the morning - thats my hot tip :thumbsup:
spotters on the long Wang mainly checking cars not leave the track...if you photographing them you will notice anyhow..
or replacing cones if they are hit. this is done when no cars on track. plus usually only happens 4-5 times as most ppl are avoiding them.
I've done it a few times just for photographing.
Laith spent the last one doing a bunch of videoing up there as well.
So is definitely possible. Ask to be up the top of the earth bank and you get heaps visibility for the wang as well.
M
Sounds good, happy to do it. What time does morning runs start?
I'm taking sickie friday and going to shep friday night so will be able to get there early.
Should I bring my HIVIS or will one be supplied if volunteering?
Bring your own high vis if you can - just in case we dont have enough
Oh and Brisby Welcome home!!!
I dont wanna ring in case your sleeping at odd times, but give me a call and maybe we can work something out :D
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
