Very happy thanks Dale i dont thimk think dynosheet has a torque curve but been thinking bout taking my car up to Jezzy boys dyno just for a direct comparison on 2 dynos and also to get a torque read out
Very stout result Mick. You've got to be pretty chuffed with that. My estimate was well shy of the mark, thought the manifold would have become a problem for flow around 320kW.
+1 for graph with a readable scale (rpm on X axis if possible)
+1 also for a look at the torque curve please.
Awesome, I bet it is.... its actually roughly the area I was hoping to see, basically says that its capable of making as much as a stock RB25 with stock manifolds can. With a decent highmount and plenum I'd say the wee GTX3071R has more to offer, too. Definite win for a stock manifold setup, though :)
...on farking corn fuel :) Gone are the days where people are chasing numbers on 98. Come on Caltex, forget Commodore company cars...the performance enthusiast is a bigger market...get more servos stocking it
+11ty
Only 30hp shy of my T67 on a dyno dynamics dyno and by the looks a fair bit better down low :thumbsup:
Makes me wonder how one of these would go in external gate form >_<
PS. Take a better picture of the graph, I can't see shit down the bottom haha
Argh, who starts a dyno run at 3900rpm haha... Makes the curve look so much better than it actually is!
Probably not as good as I thought it was down low compared with a T67, actually may be a tad on the laggier side.
But in saying that it's a very impressive set up for a low mount standard inlet and exhaust manifold set up
Edited by SimonR32
Seriously? A bigger non ball bearing turbo being less laggier?
Not taking away from the results for a second. For a bolt in internal gate setup its brilliant and un heard of power and response 5 years ago. But have to say I am a bit disappointed its not making 200rwkws until around 4,300rpm which is only 200rpm better then my RB20 with a TD06-20G on 98. I am really looking for a 330-350rwkws setup that does 200rwkws at 4,000rpm.
I wonder if something like a Full Race manifold, twin gate and GTX3071R on a std RB25 would do over 200rwkws at 4,000rpm?
Ah ok - if that turns out to be the case this it seems the GTX3071R is a bit like the other GTX turbos, as laggy as (or even slightly laggier) than the next size up wheel would be anyway sad.gif At least it flows more, too!
Can't really be compared with a T67 though, with a 6boost manifold and external it would probably improve by a few hundred rpm in spool and gain a few healthy killerwhats.
Fingers crossed the latest fixes and the 25G make you happier!
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
