  • Replies 128
Posted Images
Good day all! Very well run and the weather held out just nicely. Pity about my little incident at the end, which has left me with a fractured wrist but what can you do. Glad to hear the driver of the green WRX is A-OK.
Thanks for organising the garage Martin, much appreciated mate :cheers:
Ouch....sorry to read that Dane. Hopefully nothing too serious is wrong with the car and you are back out in no time.
Just make sure you get the missus to do all the work and that wrist will heal in no time ;):P
Hope you and the car are on Dane! Would love to see the video of what happened (if you're comfortable with John posting it online)
Congrats to all who did PB's, the conditions were great for quick times. Luke deserves a special mention with a 1:20.46 screamer! Dipping in to the 1:20's is awesome.
Yeah another great track day!
Good to meet some more of you and catchup with a few people from previous days. That was my 3rd track day and definately hooked.
4 x R34 GTRs was great to see.
thanks to the WRX club for putting it on.
Russ: Me either mate! Thought it was jarred/sprained but got progressively worse and now I'm in a cast... balls!
John: Nice vid mate! Basically I was fiddling with my camera between 1 & 2, lost a bit of concentration, went in too hot on tyres that weren't up to full temp and you can see the result. Stupid mistake by me, but a lesson learned. Luckily the car is fine, just a bit of cosmetic damage to the lip, front dive plane, light cover and rear guard but it's getting fixed up now. :thumbsup:
Ant: I'm trying mate, with little success... :teehee:
Thanks for the well wishes guys!
Sorry to hear about the broken wrist, ouch and glad to hear wasn't major car damage so both are on the mend.
Thanks to Russ, Martin, John for your advice, will post findings in the brakes thread but I talked to GSL RallySport who mentioned A1RMs but if I don’t mind spending more, they reckon I should try Project mu’s Club Racer pads for longer track pad life and do work from cold. I’ll have them in for the SAU nationals. Note I had no issues with repeating the same setup but as I’m starting out, seems sensible to test a few setups.
club racers are working really well in my car now. 7 track days and 1 deca and about half worn although the G4 does have a massive pad surface are. I'm impressed. :)
Thanks John :thumbsup:
As far as pads are concerned I use Project Mu HC+'s in the STi, and have in several cars. Great pad, work well from cold and last the distance. Would highly recommend them mate.
How is the bite on them?
I wasnt a fan of the Ferrodo DS3000
So thinking either Pagid RS29, or perhaps another pad.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
