Thought I would test it while I had stockers on the car while the 2530's are being modified
Attached some typical data, copied from pfc log, clutter removed
so its basically time, rpm, speed, boost, tps
Tab 1 no water injection
Tab 2 pre turbo switched on @10psi
Tab 3 pre turbo switched on @2psi
No post turbo water injection
50/50 water meth
each turbo has a 70cc/min nozzle which has been tested
Full throttle is 3.9v
All are 3rd gear from about 2k and nailing it
No timing or duty changes
Highlighted from 3 to 8psi, 8 to 13 psi, 13 psi to 16 psi with time differences manually typed in
Im in the mindset of disregarding boost vs rpm as the stockers spool really quickly
I would like to test larger nozzles but I dont have any larger pairs
pre turbo WI.xls
https://www.sau.com.au/forums/topic/375580-pre-turbo-water-injection/
turbo responce is actually slower when you consider boost Vs. time. I have a couple of logs from about 2k to about 150klm back to back which shows a 0.7s reduction in time with pre turbo WI on.
They are stock turbos, which were run for about 5-6 years at 17-18 psi so they are worthless anyway. I would like to see the effects on stockers before I consider using it on anything worth while.
Comp wheel damage is possible which is why im trying it on shitters. Not so sure on how the housings will get damaged though
hopefully none of the comp wheel breaks away and goes through the engine...
If it does, all you can do is laugh really.
Or it might then unsettle the shaft due to the RPM, and send the exhaust wheel dust back in.
attack on both fronts, sure to make the tops of the piston look cool.
draw through set ups 15-20 years ago (and more) wern't breaking comp wheels
with fluid volumes significantly higher then 2x 70cc nozzles.
i'll take pics if it happens
water is actually extremely abrasive, especially under certain conditions...
Hey dude, can you film this shit every time you run this water injection experiment. Its going to end in an awesome failure on those stock turbos n i want to see that shit go down. I need a good laugh over my morning coffee n that just the number to do it :thumbsup:
for some reason all this is reminding me of this clip
which also provided coffee laughs for me a few years ago...
If your just using a water jet, yeh it will wear the comp wheel quite quick, as for making it break...ROFLMAO...it rounds of the edges first on the blade tip....
To give the comp wheel a fighting chance you need a nozzle that squirts water and air separatly to break the water into finer microns
Injecting water without tuning is just going to result in lag and usually less power, you need to
1. add timing
2. or add boost to make it work
If you dynoed the car with maxed out the stock compressors and add as much timing on 98 octane as you could to reach MBT, and then
put the water injection on and did the same again, then that would be interesting reading
but atm, this thread is a whole lot of nothing
cheers
darren
Give credit where it's due. A member is trying something that most people only get to talk about. Yes there may be some negative impacts on turbocharger life depending on how the water is introduced; and no there may be no actual performance improvement depending on what (if any) changes are done to the fuel and ignition mapping.
There is a wealth of information to be found on this forum: http://www.waterinjection.info/
But the OP is doing his best to share results in a quantifiable form. I say lets see what transpires and learn from the experience.
^^^I agree, i just know from playing with WI, that there will be no gains without tuning changes, if the OP does what i said
it would be a very interesting read, my mate many many yrs ago,when the fastest gtrs in the land only ran low 11's , had a stock 32 Gtr with just a dodgy water injection setup with a washer bottle motor and a piece of copper pipe on 1.2 bar
stock turbo's, stock computer, stock injectors , shifted timing via crank angle sensor, car ran 11.4 at 121mph on pump
he then fitted stock r34 turbo's, it then went 11.3 at 124mph, embrassed all the big dollars spenders with there hks low mounts way back then.
So it can be fun to play with!
edit: i remember now, the stock pump was hardwired and it had a teed off extra injector(550cc) triggered of a hobbs pressure switch
cheers
darren
Edited by jet_r31
VW enthusiests in the US have been using draw water/meth systems for years. Part of the reason is that many of them are using pull through turbo carburator setups. The general concensis is that provided the vaporisation is good, turbine damage is minimal. There is plenty of informaiton on www.shoptalkforums.com.
They aren't injecting a lot of water/meth though, as the typical turbo setup in a VW is rarely more than 300hp. Mind you that power in a 780kg car is plenty of power. Its usually through a 45-55 sized idle jet with a washer bottle pump supplying the flow, injected into the center of the pod filter or ahead of the carb aux venturis.
The advantage is that they are able to run 20lb boost on 8:1 CR engines with no intercooling, yet still run a mechanical advance distributor with a full ignition advance of 30-32 degrees. They run their crappy 91 octane fuel as well.
So as has been said, there is little point in injecting unless your tuning to take advantage of the raised effective octane rating. The only benefit is the steam cleaning the combustion chambers. Without tuning for it, you will actually lose power as the flame front of the burn in the combustion chamber is slower. Same effect as putting C16 into a car tuned for 91 octane.
Good to see someone having a go though. If everyone just did the same as everyone else the world would be pretty boring.
have read many things about WI , as stated above it must enter as a mist or it will cut thru the turbo. .another benefit is that it breaks down the carbon that sits on your pistons and in the combustion chambers, go for it mate and keep us posted on your results including stuff like if the cars fuel consumption changes :thumbsup:
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
