Hey guys about to buy a 95 R33, mint with the following mods:
19" wheels.
3.5" stainless cat back exhaust system.
Stainless split dump pipe.
E-manage ultimate.
HDi Digital boost controller.
Blitz turbo timer.
GCG high flow turbo.
Air to water intercooler.
Pod air filter and custom fabricated cold air intake.
Towbar.
4 new 235/35/19 tyres
Coil packs just replaced with Yellow jackets
Wabro hich flow fuel pump
Thing is the guy has a dyno sheet reading just 200kw, this seems a little low for a gcg high flow? He doesnt mention injectors so could he just be running out of fuel? He got it tuned at some small workshop ive never heard of so perhaps the tune is crap.
Would bigger injectors and a z32 airflow meter+retune by matty spry or gavin wood net more power? Whats the best place to get new injectors and the afm?
https://www.sau.com.au/forums/topic/375655-200kw-a-little-low/
If he hasn't swapped the injectors over then that would be about right. Mine maxed out around there. I haven't personally used a gcg highflow but if the stock turbo can make around 200rwkw at 14psi then a high flow will put out a lot more. Here is a link to the same person I bought my injectors from. http://www.ebay.com.au/itm/6-660cc-Fuel-injectors-Nissan-Skyline-RB25DET-300zx-TT-/120768070761?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c1e568469 I spoke to them very recently and they have a 900cc set there that work fine but have cosmetic damage only. They mentioned they would be discounted because of this. I payed around $500 for my 900cc's so you would expect to pay less. All these injectors have been used but are refurbished. Get a new afm from any auto store that we all go to on the weekend. Or a second hand one from the classifieds here. Make sure you get a plug for the afm too. In my opinion there is a big difference between a mechanic and a tuner.
I was going to say it was the 19" wheels!!
I recommend at least 21" which should give you an easy 300rwkw.
:cheers:
Man I was wondering about that. So you're saying if I swap the multifit lenso 19's on my commodore to my skyrine it will go quicker? But then the commodore will have to get a set of stockies and will look even more like shit. :P What would a stock ride height r33 look like with 19's anyway. The entire wheel is bigger. It might turn it into a 4x4. That would mean I can swap the gts25t sticker to a gtr badge hey! :merli:
Bit hard on the poor guy!
Yes mate 200 is too low - the turbo should be good for 250 - 260rwkw with a Z32 afm and bigger injectors if all else is in good nick and the intercooler is rated for the job.
Still even eith stock afm and injectors youd expect maybe 220 kw unless its a low reading dyno. How much boost it it at?
I would still xheck it out and maybe do a compression check if your keen on it.
Only jokin fella. You may get a little more power from the stock injectors and afm. If the afm is at 5 and a bit volts then there isn't much you can do except swap it out. My stock injectors were hitting 95-100% regularly and the stock afm was hitting 5.1 volts regularly to get between 190 and 200 rwkw. That was with the stock fuel pump.
How much boost is the guy running? I'm getting 200rwkw @ 10psi with my gcg high flow (low boost setting) +z32, walbro, stock injectors.
May be slightly off topic but where does everyone get the idea stock injectors max at 200rwkw? My high boost setting is set to 16psi and making 260rwkw with standard injectors, standard reg, z32 + nistune by Toshi from our forum. I watched my car on the dyno pulling this figure with stock injectors and told was even still able to push a little bit more out of the stock injectors. But then again it does seem sensible to upgrade the injectors, I just got a bit lazy :P
If he has stock injectors and afm and hence is limited to 10-12psi then yes it sounds completely normal.
My gcg highflow made 210rwkw on 12psi and 240kw on 18psi, depends on what turbo has been used and what wheels it has.
Injectors, fuel pump, afm and a retune shouldn't set you back much over $1500, though if you are buying a car why not just keep looking and find something that a) makes the power you want, and b) doesn't have gay ass chromies on it.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
