On 22/6/2025 at 9:45 PM, Milkmun said:
The stealth of it is sick. Custom tow bar I assume?
Yes customized and built from scratch pretty much after finally finding a local towbar supply and install place that was willing to do something "different".
Very happy with it for sure 👌
  • Like 1
Do you mind if I ask how much this cost to get setup?
Currently I put a rear rack on my bike, load up a duffle bag and ride to the track. The ride home can get a bit sketchy with how exhausted I am, if this isn't crazy expensive it would be a much better option for sure.
  • Like 2
It cost me $2900 all up for a local trailer / towbar place to supply and install. I did think it was a bit steep initially but after all the work involved and seeing the final result I think its well justified.
Hardest part was finding someone willing to customize and fit it up with trial and error basically.
Whereabouts are you located? - I had my work done locally in Wangara.
It sounds "expensive" when compared to a mass produced tow bar that gets imported from China, but if that's all custom fabrication, then I think where you've ended up, it's a pretty good price! Considering some people will pay thousands of dollars for a few intercooler pipes to be welded up!
  • Like 1
Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.
I'm a long way from you mate, I'm a couple of hours out of Brizzy.
  • Like 2
  • 3 weeks later...
Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
att.HD-mjlbhCOHOTxHzOJxx3GbigiUtMbN5pJOJrz6cJeQ.thumb.jpeg.f4bf325a1f31a714be6b9b3d177b6efd.jpeg
  • Like 3
10 minutes ago, GTSBoy said:
Given the absence of lower parts, I'd suggest that they are just draped over the backrest for aesthetics in the photo.
I'm guessing its a 4 point harness, 3 of the 4 belts are visible. I'm guessing the hidden belt is tucked down between the seat and door.
  • Like 1
Lower parts are there. On passenger seat, bright yellow bit is the release mount. On drivers, bright yellow bit is the lower buckle for the other side.
My bet is lowers are tucked out of the way as much as possible for visuals.
  • Like 1
  • 3 weeks later...
  • 1 month later...
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
