Installed these things last night. Ride quality is excellent. Dont have a bad word about them except for the left rear. It has a knock, now It is tight as hell, I reinstalled it at least 3 times. Went to justjap this morning and the guy said could be the bearing under the top hat. Will be getting a replacement soon. Other than that, they are tits.
we all love pics....
Definately track time now :thumbsup:
5 may I'm going.
Other than that I'm going to replace the perishable items on the car, just bring it to the 21st century.
Thanks mate, it's a nice colour when it's clean, which is usually not long after a wash. Haha
Beaut car mate. And i normally hate 33's! Shoulda gone for 10.5 +15 wheels imo! Oh and it still is 4x4 height! Drop it on its belly.
All in all very nice! :D
What you mean 10.5+15? thats what they are............
haha, nah man, Ive been there, I hate going sideways over speed bumps and circumnavigating the f**king street. Oh and dont even get me started on driveways.
Hey mate, thought I better post up in this one instead of the shuffle thread ;-) I see that you put some BC's in her - I got some of those the other day too and put them in on the weekend. Just wondering if you had any issues with getting the car to sit level at the front seeing that the things a lot heavier on the driver's side?? When I installed mine it started to want to pull to the left and now I'd probably need some adjustable castor arms etc to correct it. (or put it up a bit higher again)
Yeh I went around and measured each corner from 3 points on the car till I finally got front level and rear level....took ages man!
Yep I did get one but it didn't improve things much - there isn't much to adjust on and a stock GTR steering setup =/ They were able to change general alignment and toe but when it comes to castor and camber corrections there's not much that u can do :(
How flat is the road where you're doing it? Sounds weird to me that it decided to sag more on one side. I set mine up at the same height on both sides, on the coilover. And left it at that.
Got my wheel alignment and car drives great. Handles real nice and doesn't jar my teeth :).
I did it on a dead flat concreted area...and even did it on another area just to double check. But then, when jacking the car up she's noticeably heavier on the front driver corner.
Yeh you gotta love them...I have mine set to about 15/30, so medium setting and she's good around town....could even soften her a little more but that means taking the parcel shelf out again :P
  • 2 months later...
So it would seem i have been a bit lazy updating the thread.
Had a problem with the walbro 400lph not sucking when the tank was 1/4 full. Seems the design of the pump is to be submersed the entire time. So out that went and in came a bosche 044. No biggy there, pump operates until the tank is empty.
Ever since i got the coils the car has been seeing a lot of twisties. She drives good and it is apparent that the achilles tyres that i have on there does not complement the handeling capability of the car. Never the less she corners hard, drives hard and makes me....
Anywho, i want to bring the mid range up so the car is going to get cam gears timing belt water pump all that hazz done. Thought id give good old jez a shot seeing as how word on the grapevine keeps tellibg me good things. Dont let me down jez :P.
Oh, with all that sunami rain sdney has been seeing, i foubd out that my boot leaked. What a bitch that was! I literally siliconed everything! Should just have filled the sides with putty haha. But it seems as though all is well.
Ill be comparing my first dyno sheet to the one i get from jez, so if anyone is wondering what sort of difference there is it will be here soon.
Unless my engine goes kablam. :S do not want.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
