Customer is having problems with his fridge. Sent out a fridge mechanic to fix it for him at my expense not once, but twice. And he wasn't there both times after we agreed on the time. And he still thinks he can call the shots etc after making me pay for two service call fees. Yeah nah buddy.
Oh grip, how I had missed thee
Could have used some brackup on Friday night...there were heaps of partnerships :(
On the plus side, the club owner is looking after us now :thumbsup:
Dear statusengineering,
can we buy a close ratio toploader
- glen71torana
Dear glen71torana,
We have two types, one has an overdrive 4th gear and the other has a straight through 4th, which one is the close ratio?
- statusengineering
by close ratio i mean the gears are close together ,so the shifting distance is short like in the xy gt,s
- glen71torana
-_-
3-4 a day, at least.
These are just the eBay questions; people who actually know how to use a computer. The phone calls = myheadisfulloff**k.jpg
f**king hell...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
