Customer is having problems with his fridge. Sent out a fridge mechanic to fix it for him at my expense not once, but twice. And he wasn't there both times after we agreed on the time. And he still thinks he can call the shots etc after making me pay for two service call fees. Yeah nah buddy.
Oh grip, how I had missed thee
Could have used some brackup on Friday night...there were heaps of partnerships :(
On the plus side, the club owner is looking after us now :thumbsup:
Dear statusengineering,
can we buy a close ratio toploader
- glen71torana
Dear glen71torana,
We have two types, one has an overdrive 4th gear and the other has a straight through 4th, which one is the close ratio?
- statusengineering
by close ratio i mean the gears are close together ,so the shifting distance is short like in the xy gt,s
- glen71torana
-_-
3-4 a day, at least.
These are just the eBay questions; people who actually know how to use a computer. The phone calls = myheadisfulloff**k.jpg
f**king hell...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
