Tony, what are you decorating it with?
Room is quite small. So just posters on the walls at this stage. It's quite a dull room.
his pubes.
Did not need the thought of pubes whilst eating lunch.
no its not.. its just fkn hot. i wish I didnt have this gut.. lol shouldve started gym a lot earlier.
Still got time mang.
I have a gut too....forever bulking lol
I got zero energy in the mornings and walk around like a zombie at work till about lunch.
Good work though in gyming before work. That's determination for you :thumbsup:
not really an effort.. i cant really sleep after 5am on any given day.. so it works out i guess.
10.30 to 11pm...
doesnt really matter what time I go to sleep, if its before 1am, I will wake up before 5, and be wide awake..
I see your using Arnie's trick of sleeping faster
Dude. Just accept the fact cheezetv isnt on anymore.
Well played mohomo
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
