Tony, what are you decorating it with?
Room is quite small. So just posters on the walls at this stage. It's quite a dull room.
his pubes.
Did not need the thought of pubes whilst eating lunch.
no its not.. its just fkn hot. i wish I didnt have this gut.. lol shouldve started gym a lot earlier.
Still got time mang.
I have a gut too....forever bulking lol
I got zero energy in the mornings and walk around like a zombie at work till about lunch.
Good work though in gyming before work. That's determination for you :thumbsup:
not really an effort.. i cant really sleep after 5am on any given day.. so it works out i guess.
10.30 to 11pm...
doesnt really matter what time I go to sleep, if its before 1am, I will wake up before 5, and be wide awake..
I see your using Arnie's trick of sleeping faster
Dude. Just accept the fact cheezetv isnt on anymore.
Well played mohomo
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
