Sometimes it does my head in. I would love to have a daily instead
fair enough. the diff in mine shits me for Freeway driving.. its out of a 34GTR vspec, and it revs at about 3,100rpm while cruising at 100kmh
I'm not a Dutch therefore I'm not high as this chap might be.
And no way I look like him, he's 40 or something and I'm only 24!
I always thought he was signing something...
good work man. doesnt it ive you reason to just leave it and avoid problems? lol
Man, I'm so sick of your moral highground. You need to be taken down a notch. A whole notch.
People whinging about highway RPM...your engine isn't meant to labour along in top gear, nor is the gearbox. These are high revving engines with bugger all torque in the low range. If you're sick of exhaust drone, get a Varex or a better sound system / HTFU.
Mine is the same revs around 3000 when doing 100... I'm used to it now
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
