These guys whining about noise. I drove my bros n/a r34 with a straight pipe 2.75 inch exhaust 200km at 110km/h with it blasting my ears.
Just to describe how loud it was. Was driving on prinny highway. It set off car alarms of cars parked inside chadstone.
I want loud exhaust :(
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
