The GTR is now covered in bird shit, I washed it on Saturday and I can see 5 of them now...
Didn't happen same time last year, and their shit are pretty sizable, wondered what they'd ate.
The people across my house is ridiculous.
Last fortnight, seen 3 Porsches; 911 convertible, Panamera and a Cayenne...
In the garage, there's '80s Rolls Royce.
ask for their daughters hand in marriage
So far I've seen old lad with the rolls, young-ish bloke (roughly my age) with vert 911, lady with kid in Panamera and just saw Cayenne this morning but no idea whose it is.
Haven't seen the girl, was told by mum but she reckons it's young blokes missus.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
