*typical asian*
Hey you speak vietnamese? Oh I do too! *starts speaking viet and hopes for a discount* LOL!
Lol I ain't no Springvale accountant. Vietnamese talk doesn't work in the big end of town :D
Haha. Its so true though. All the viets look for salesmen who are viet too to get things cheaper. Hahaha. Bitches think it works.. :P
Does work, do it with all the builders/handymen that are working on my house at the moment :D
Orly. Bastards. Haha. My mum tries to do it with everything. Works 1 time out of 10.
can I be viet to get shit cheaper?
Lol
Better watch your back homie
On another note officially catching the springvale line now. Can't park at Glen Waverley within 400m at this time but can park at Springvale station within 10m and springvale parking is about 10x smaller.
Does that mean my car will get stolen?
rofl your car is so gone! :P
I'd trust Glen Waverly over Springy...
gimme 2kg of yabbies, i'll make you spicy chilli yabbies.
fkn yum
can i just dump two opera house nets into the pond and retrieve them overnight? but i'll be hurting the platypuses. =(
platypii?
works with most curries too, just not tamils. we are a tightfisted bunch
The Arabs try it on me. Never helping them
Again. You help them, they sting you and try and milk every little drop out of you. f**k yourselves dream boats.
Let me guess, an Arab put a Jihad on you and now we're going to see another September 11 over $600 worth of espresso maker.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
