Gotta love when your wheel has rubbed through the plastic guard liner and into your wiring loom, hope the part it chewed up was for HICAS or something else I don't have.
happened to friend's car. His fuses kept blowing. Had a look under the guards and the wheel had destroyed the whole loom. Rewired through the engine bay, s'all good.
That FT86 has a comparable power/weight ratio to a r32 gtst. I expected much better :/
FT86
power: 147kw
torque: 205nm
weight: 1250kg
power/weight: 117.6kw/tonne
R32 gtst
power: 158kw
torque: 263nm
weight: 1320kg
power/weight: 119.7kw/tonne
Integra Type-R (DC2R)
power: 141kw
torque: 178nm
weight: 1087kg
power/weight: 129.7kw/tonne
lol tony and john. both fags
i tucked mine up further into the guard. no problems
FT86
power: 147kw
torque: 205nm
weight: 1250kg
R32 gtst
power: 158kw
torque: 263nm
weight: 1320kg
power/weight: 119.7kw/tone
That's pretty poor considering you comparing it to a 20 year old car
That's the non turbo version though,
So IF they do a turbo you want to hope it's doing over 210kws at the fly
Yeah I think I'll do that on the weekend, bought it up a cm or so in the front so no more scraping, doesn't look quite as nice either though. Looks like nothing has stopped working though which is good.
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
