It took em a year to send the letter...I got it just before or just after I'd done this years return... Last year I think I did it pretty early, this year I waited a few months coz I couldn't be fked even though it only takes like 20 mins lol
ATO systems are slow to catch out peoples errors but they will catch you lol
ATO systems are getting bigger so there pulling alot of info from institutions on individuals and then data matching.
No one is safe :ninja:
Yep, only did it that year coz the interest was so much...this year it was a lot less so I claimed it...The fact I was already getting a decent return helped
It's still bullshit though, I get done for a couple of hundred while other kunce are out there completely ass f**king the system and getting away with it.
See it all the time at work Dezz. A lot of rich clients get away with a lot of dodgey shit because the accounting companies are afraid to say no otherwise they might lose the client.
A phone call Kris lol You dodgey Kent
Lots of number crunching here...
I washed the R yesterday, went to inspect my 'handiwork' just before and it needs more washing, don't ever ask me to wash your cars.
So I rkn barbs is either
A ) not really on holiday
B ) on holiday alone
C ) a mass loser
I'd say;
D ) all of above.
He is on holidays at home with LA city on wallpaper in his bedroom.
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
