Looking at an new Audi A1 MV contract of a clients.
$33,615 MV purchase price, but once you add a just a handful of extras and all the other shit you need to pay for a new MV......Amount Payable $55,820 :/
12%?
Logbook
C per km
1/3 exp
It's under the MV limit if I'm correct
12%?
Logbook
C per km
1/3 exp
Whatchu talkin about Willis? Not sure what your getting at lol
But to answer your question it is under the Luxury Car Tax Limit. It is also under the MV depreciation limit for Tax Purposes.
You have also listed down 4 methods of claiming car expenses which I'm not sure how it relates to anything lol
I'm taking about your client having a decent deduction on the vehicle based on the methods I posted up there lol
So I see, different wave lengths :)
It's under a company, so deductions are claimed outright. But then there are FBT consequences.
just what i saw, cant remember which ep of top gear, but they all chose the 370z over the m1
said it was a better car overall and the price was the last straw in the decision
yeah not to sure on exact figures
but i know 370z ain't no slug
370z was tested against a z4 not a 1m
looks wise the new z4 shits all over the 1m and the 370z is even uglier imo 350z looks better
got some quotes for powder coating at a joint in campbellfield
wheels $60 a corner
brake calipers $15 each
will do the writing on brakes myself with a paint brush or something. RIP front guards
now just need someone to come and remove these all off the car :closedeyes:
Really? IMO the z4 looks like dog balls. 1m looks tough! I think they use it as a safety car in the MotoGP.
yeah jonoe reminded me it was a z4
however i would rather a 330i over both anyway
wheels $60 a corner
i'll do it for ya man. i've even got my own angle grinder
hardtop z4s are hot. not sure about the soft tops though..
335i? yeah me too
thats terrible, thats terrible man. your mother brought you up wrong is what it is, your mother brought you up wrong mother f**ker
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
