With Turbolight - if I ever left as long as 5,000km and didn't top it up between changes (think I only did that once) I lost nearly 2L. Considering that's more than half the SR's capacity that's terrible. And it never noticeably burnt it so yeah...needless to say I started checking the oil more and eventually decided the oil just didn't suit my car. My ex's SR S15 was exactly the same, though his seemed to disappear even quicker.
With Penrite you'd nearly drain as much as you put in.
As I mentioned my RB lost Turbolight as well (although not quite as much), but again, not suited to that engine. Tappets were very noisy running Turbolight.
Too many bad experiences with Turbolight in my corner.
hmm maybe i should stop using turbolite. no wonder im losing oil i thought something was eff'd in the car.. i had a look at everything over sunday and nothing was wrong but i was loosing oil..
might move along to a 15w50 especially for the summer.
Lol barbs I'm not that Lebo :P
Johno, no it doesn't lol!
If I don't get rid of it soonish I'll splurge in some camber arms, bushes etc. mate rekons it's a rear wheel bearing causing the arse to play around.
Wheel bearings make a humming noise on acceleration/deceleration (think a plane taking off) when they go, and you'd be able to move the wheel side-to side with a shake and hear the noise when you spin it with the wheel off the ground. I have had many a wheel bearing replaced (5 on the Pulsar and 1 on the R34.)
That's the funny thing, so many people find it disappears on their SR but people keep buying it 'cause it's got 'turbo' in the name, and turbo must mean it's better.
Try the Penrite Semi Synthetic 15W60 I recommended and report back on how the car runs and how the oil situation is going. It improved not just my SR but others I know considerably. Ignore it's blurb on the website but this is the one I'm referring to: http://www.penriteoil.com.au/products/motor-oil/hpr/hpr_15 - it doesn't really sell itself with 'older engines/pre-97 family cars' but it's not very expensive so it's not going to hurt to try. I ran it on the track and on the street. It'll give your SR plenty of protection going into a hot summer. They've got nice full synthetics too but they're not really that necessary unless you're making massive power or it's a newer engine.
you replace just the bearing or whole hub? i need to do my rear left
Whole rear drivers side hub, Nissan had one in stock in the country at the time. It wasn't cheap, at all.
Stupid ripple strip, it ruined my sideways.
Try the Penrite Semi Synthetic 15W60 I recommended and report back on how the car runs and how the oil situation is going. It improved not just my SR but others I know considerably. Ignore it's blurb on the website but this is the one I'm referring to: http://www.penriteoi...-oil/hpr/hpr_15 - it doesn't really sell itself with 'older engines/pre-97 family cars' but it's not very expensive so it's not going to hurt to try. I ran it on the track and on the street. It'll give your SR plenty of protection going into a hot summer. They've got nice full synthetics too but they're not really that necessary unless you're making massive power or it's a newer engine.
i just bought it because it was 1 down from 300v.
the SR I have has only done about 30-40,000km.. its a built motor.. and i did notice after doing the first service with turbolite the forgie rattle was a tad louder.. no harm in trying.. ill see how it goes or might just go the 100% synth if the price gap isnt too large.. ill report back. was doing the second service on it coming weekend.
plus mine takes about 5 and a bit litres with the ARC sump extension and oil cooler..
lol aint it all the same? just a different company supplying the credz?
Sort of the same. Depends on where you work. But CA is alot harder than CPA.
Had alot of people at our firm come from CPA backgrounds, try the CA and then fail hard. Failure rate in CA is pretty high. And when someone fails at work they usually cry, because you've just wasted money and 1/2 a year studying your arse off outside a full time job for nothing...
can get bearing from just jap for like $160 compared to 250 from nissan probably just go that way
I was in a bit of a hurry to get my car back so I didn't search but Nissan were damn expensive I agree.
Did you cry? It's ok brah you can tell us
Oh that's pretty young, it shouldn't be losing oil like that! Maybe a full synth seeing as it's still a young engine? If it's in your budget that is: http://www.penriteoil.com.au/products/motor-oil/sin/sin_engine_oil_10
Oh that's pretty young, it shouldn't be losing oil like that! Maybe a full synth seeing as it's still a young engine? If it's in your budget that is: http://www.penriteoi...n_engine_oil_10
nah i put 5 litres in, and about 3.5-4 litres come out.. i know im losing a tad through the turbo as well. we'll see how it goes.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
