V-series are a chopped up sedans slammed with two doors.
Z zeries however are purpose built, designed and engineered performance cars imo.
I fell in love with it when i saw this ad
no,
the v series are practical cars that handle as well as a z and are as fast as a z. i'd go v36 370gt.
I really hate the shape of the V-series Skylines, they're just not proportionate on either end of the body.
This however, like the last of 300zx's, will retain its beauty for years to come. It's a design that will really age well and still look modern in 10 years time.
Get one then fag
Is that 360? Lol
Barbs is single cos he likes men.
Drive was shit. Bareable but disspponting given the astronomical cost of going to the cinema these days
Don't make me dig up the "I make a zillion bucks I don't mind paying for my mrs" quote :nyaanyaa:
Haha you can earn a million bucks but if you spend a million and one your broke!
Cinemas are a massive rip off it's disgusting what they charge, same with everything though it's the families I feel sorry for try taking family to a game of afl $150 easyyyyyy gone, cinemas for family is easy 100+
Dont talk to me about money mr lawyer! One of my clients is paying $16.50 per minute for her lawyer! PER MINUTE!
Haha maybe one day :cool:
Hey, Rik is a labourer until next year...
I don't even do that anymore.. Also spell my name right ffs
Yo Dezz:
$16.50 a minute not bad. One of the lawyers we used at our firms court case was about $3000/hour.
So I guess if he got up and made himself a coffee for 5 mins it would cost you $250 :D
The Game Touring Australia/New Zealand, February 2012: Pre-release tickets go on sale on Monday! We have a special online offer, there's early-bird tickets at a special price of $59.95 – very limited. We have VIP meet & greet tickets for sale for $149.95 & again VERY limited. Dates & Ticket info at www.AbleTouring.com
I'm pretty keen for it
Project C-X75 will offer performance that surpasses the fastest production cars on the market, while adopting cutting-edge technology for remarkably economical running. Delivering a sub-three second 0-60mph time and a top speed in excess of 200mph. Crucially, this performance will be generated alongside incredibly low emissions, less than 99g/km CO2, thanks to the lightweight construction and cutting-edge powertrain technology.
Top speed in excess of 200mph, 0-60mph in less than 3 seconds and 0-100mph in less than 6 seconds.
An underbody system incorporates a moveable aerofoil and directional control of exhaust gases to ensure maximum downforce and ultra-low drag.
Yeh top end corporate lawyers are spastic charges
16.50 a minute is local corner shop lawyer.. Still a decnt earn
Don't know how people can think their time is worth $3000 an hour...whatever people are willing to pay I guess. Annoying thing about being a lawyer would be the constant phone calls / questions from people just wanting to ask questions with no intention of paying for time etc.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
