Money.
For pair of steel wheeled turbos, PFC, injectors, afm, exhaust, labour money to fit these plus nismo clutch I've got sitting in garage for a while.
And many more things such as swaybars, arms, tyres for the rims, alignment, hicas lock bar.
It doesn't end!
I meant by just removing the boost restrictor in the mean time. Would only take a few minutes?
ok the lease rules are oldest model allowed is 2007/2008
only found evo ix 07 which is like 40k pfft
where is nick he will know of a 2007 IX for cheap
Go the Emo!
Yes, it'll take few minutes but with exhaust, will give you better results with minimal restriction.
I had 302rwkw and 270rwkw GTR before this one, I'd want more power than just boost restrictor pulled out.
Because a evo would eat a GTST for breakfast
No doubt about that, it would run rings around a gtst.. but just the sound of a straight 6 is worth holding on to.
Then again i am biased and would probably never own a 4 pot as a performance car, just the idea of modding a 4 pot sounds too funny.
Edited by Flynnn
You Guys remember my remark about Shan getting his beloved doggy stuffed and keeping it forever..
Well I found a stuffed German shepherd in the garage last night. No joke, I don't know how it got there...
But it's a fkn baws.
Tell that to the worked 8MR i met last week LOL
I'm talking stock vs stock, because I'm guessing Pauls looking at just leaving it standard? Obviously more expensive but you get a newer car.
Put money into any car and it can rape any other car..
One of my S15s is putting out 285rwkw on E85 :nyaanyaa:
It's all relative...
Pics or ban.
and to be fair im not buying the evo cos its got tons of power or its super quick
buying it, or looking at it cos its a nice all rounder
my gtst has 240k and probably 160rwkw and i call that quick enough
2012 GTR to do the 1/4 mile in ~10.6-10.7 seconds. Are you positively annoyed friend?
http://www.insideline.com/nissan/gt-r/2013/2013-nissan-gt-r-first-drive.html
Meh, current model ZX14R does it in 9.8 :P
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
