alex you just need this part with no other code or tags around it,
http://www.youtube.com/watch?v=2muQaGex-pw
just make sure you got watch?v=2muQaGex-pw and cut off any other crap off the url, generally added when browsing through related videos etc.
http://www.youtube.c...h?v=2muQaGex-pw
lol.. indian michelin man
david guetta special on GO...pretty cool... :D
alex u just copy and paste the link man ( browser addres whatever u call it)...if it say something liek "feature related" at the end delete that bit..birds tawt me that :thumbsup:
Shit...haven't replied to your PM lol, will do that tomorrow.
Who's a GTR expert here?
Trying to help a friend replace his leaking stock R32 GTR injectors.
Can anyone confirm if the below information is correct? He has no after market ECU at the moment so fitting a bigger injector would probably mean his car won't run so his looking for a stock replacement atm.
Where my dogs at?
Black people had some groove, style and most importantly education back in the 60's & 70's mayne.. singing and rhyming to tunes of jazz and soul music... now however, lets not go there.
I walked into a wallmart in Culver City to find an adapter for my charger and boy was i for a surprise. The most arrogant, ignorant and most importantly poor (wealth wise) people I've met in my life. I was the only white person in the entire complex that was swarming with all black folks in all three levels.
US is phucked and i don't see it ever recovering from the decades of degeneration.
Be thankful your folks were granted a citizenship to this country and not to US, although Canada's pretty good too from i hear, so show your gratitude once in a while you maggot. Otherwise your folks would have migrated from one ghetto to another cause end of the day, parts of US is just that, an urban ghetto.
Tony, how many problems does Justin have with his GTR ATM?
Injector leaking... Had he tested the body itself? If so, what are the results. If body is fine, grab new seals.
Factory are 440cc low impedance and this seller is selling high impedance so won't work at all unless the ecu is some fancy aftermarket unit (motec, haltech, etc).
Cheers Grant, well it is a 1989 model so is in need of some TLC
Strange seller is trying to sell something that doesn't work because its a reply from a company workshop rather than a private seller.
i wouldnt call that racist though he's just stating an observation. a completely useless and irrelevant observation nonetheless
How is his stereotypical view of black people not racist?
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
