Typical asians and their camrys.
Yes, I will definitely not get a camry when I get a family car :/
Fawk you eastern burbians.. living on the other end of the city, away from civilization lol
You live close to Birdman, Tony
Disclaimer: It's a very nice clean burbian area, nice and quite :)
Lol, quickly removed the address incase someone wants to steal an Evo
Time to bring out the ol log book and forge 120 hours.
Holyshit last entry july last year. LOL!
You guys and your 120hr log book.
When I did mine I booked 6 driving lessons then went for my P's. Like a baws
I was gonna say something about the personal details thingy.. but kept silent as i post too much already and offend people lol
yeah so my injectors on my GTR are shagged and i want to throw in 750's. but my question to you all is, will it be ok to drive? i know itll run rich. real rich. but will there be any massive problems that i can avoid? obviously some fuel might or probably will leak into the sump but thatll be a quick fix with a oil change before i get a tune done HOPEFULLY in a few weeks.
what do you think?
Getting paid $25 a day just to drive to work, and $4 an hour just for working on this site.
Projected gross income looking pretty good for a first year apprentice :)
You sure that's right?
Say you work 8 Hours that's $57 a day or $285 a week?
what do you think?
Why Herro dere Justine. Pretty sure car would be undriveable.
Well fingers crossed you'll pull the big bucks in a few years
I make around $200 a week from counter strike. I don't even have to do anything :D
LoL getting paid to play games? What is this? You must be really good at it then
I used to play comp, only won like $500 in a year. Lol. That was when I was 14 or so.
But now I own a gaming community/network. :]
And I got ads on my server, so every join is $ for me. 1000 joins = $2.50
My servers are pretty popular so I'm doing good. Hehe. Almost $10k a year for doing nothing, for my age. I'm not complaining.Servers basically run themselves now. I don't do anything besides pay the bills for them ($50 a month)
Edited by PENGUYEN
Good shit, I stopped playing ages ago but used to play Quake 2 and 3 back in the day. Was pretty good at it represented in comps/clans and was in a Aus V NZ battle.
Entrepreneurial skills right there, all disclosed in your Tax Return of course :ninja:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
