What's in the package apart from the seat?
No point going through a 3rd party unless there's something to be gained, just get them from ticketek/ticket master (whichever is handling it)
Not sure, haven't ever really enquired about it. But i don't think it's just a seat rather more of a lounge/verandah area over looking the straight where you hang like a baws.
But I'm sure there different types of Packages etc...
But yeah probably better to go direct, unless you want somehing more than just seats.
do let me know if you do indeed make inquiries
Nice job on the renovations too, incredible transformation. Do the work yourself? or just tradie mates, or just paid for it?
Will ask at the next meeting.
We designed, and sourced all the parts. This is everything from the cabinets and benchtops down to the toilet roll holders. Then paid a handyman to fit and install. Wouldn't have been able to do the electrical/plumbing/knocking down walls etc...
Quotes for a professional to do it from start to finish including design was $100k plus. $40-50k for Kitchen, $30k for bathroom and $20-30k for the moving of walls, installation of new beams etc
We we're able to do it for a 1/4 of the price including all new appliances and a whole lot of other work to the house as well.
Also looks like I was wrong about the pay from Coles :whistling:
Don't have records going back when I was 15 but
When I was 18 I was on $11.51
When I was 21 I was on $18.71. Quite a big jump
Obviously I remember being richer than I really was when I was younger, then again everything was much cheaper back then :D
get the ducati street fighter just so you can say that name when asked...
That's next on the cards for me. 1198 bits of love. Nom nom nom.
I just died and went to heaven:
Edited by Cha_Chaos
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
