I forgot to mention Tony but your new interior looks sensational mate, its beautifully executed and color matched giving it a more contemporary living space. I bet you now feel the need/want to spend your time more indoors and appreciate the new modern space rather than being out and about. You have completely transformed the old dull, weary interior to something exceeding today's standards, well done.
Now if you could carry what you have done to the exterior of your dwelling as well, then you'd have some pimpin house in your suburb brah.
Edited by Flynnn
Thanks Kadir, it's been alot of work and a long journey.
As for the outside, once the gardening and grass has grown. The only way to make the exterior of the house more modern is to paint or do a bit of rendering. I'll see if I can be bothered doing it in due course
Kinda like this:
Makes a big difference to the look of the house externally
Kinda like this:
Agreed.
If you could color code some areas of the exterior and add some panels even though it may not serve any purpose other than aesthetics.
Rendering the front of the house or the sides exposed to road with a lighter color and adding some darker shades to it,
i.e.
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
