quote name='Flynnn' timestamp='1322784859' post='6136024']
Been getting into some Hip Hop lately due to my friend, who's a big fan of all this shit, so naturally i get to listen to some of it. She goes to all to major gigs like supafest, yesterdays emeniem concert etc. See my Hip Hop thread in Wasteland
Though i must say I do get turned on by French electro shit
maybe nsfw aaron. fyi
Take Friday off...stay up til 3am, wake up at 8:30am and struggle to get back to sleep fml.
Grant why do you want such a loud exhaust? Can you actually hear it if it's mega loud or does it make more/bigger vibrations? Not worth it for the EPAs dude.,,
Man, last night work xmas party was out till 3am then had to front up to work at 9 ..... yeerrr and right now f*kn soooo seedy
Mr Oizo? Busy P? Justice? You clearly don't know a lot brah, a 5 minute Google search and linking 11ty pics and you think you're some guru.
That's the extent of his 'expertise' on pretty much every topic he drivels on about. He usually tries to make them abstract and as far from mainstream as possible, I assume in attempt to seem different and thereby 'cool'
woof woof....
First you say "i try to" be different from mainstream then judge my knowledge on my music.
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
