quote name='Flynnn' timestamp='1322784859' post='6136024']
Been getting into some Hip Hop lately due to my friend, who's a big fan of all this shit, so naturally i get to listen to some of it. She goes to all to major gigs like supafest, yesterdays emeniem concert etc. See my Hip Hop thread in Wasteland
Though i must say I do get turned on by French electro shit
maybe nsfw aaron. fyi
Take Friday off...stay up til 3am, wake up at 8:30am and struggle to get back to sleep fml.
Grant why do you want such a loud exhaust? Can you actually hear it if it's mega loud or does it make more/bigger vibrations? Not worth it for the EPAs dude.,,
Man, last night work xmas party was out till 3am then had to front up to work at 9 ..... yeerrr and right now f*kn soooo seedy
Mr Oizo? Busy P? Justice? You clearly don't know a lot brah, a 5 minute Google search and linking 11ty pics and you think you're some guru.
That's the extent of his 'expertise' on pretty much every topic he drivels on about. He usually tries to make them abstract and as far from mainstream as possible, I assume in attempt to seem different and thereby 'cool'
woof woof....
First you say "i try to" be different from mainstream then judge my knowledge on my music.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
