Daft Punk (duo),Cassius, Groove Armada from 90's are pioneers of House/Electro House music phaggot, they shaped and influenced hundreds of other producers of todays.
When was the last time you heard a Booka Shade or a Fedde Le Grand set matey? Should follow my contemporary electronic thread in wasteland closely...
http://www.skylinesaustralia.com/forums/topic/243036-contemporary-electronica-thread/page__st__420
Seen both of them live. Have you? I don't see how that is relevant though, you're just mad that I exposed your dearth of knowledge and piecemeal approach to 'researching' any given topic.
Thanks for the link, I will consult it during subsequent attempts to discredit you.
Brb googling XYZ so I can lecture the wasteland about it
You're clutching at straws and bouncing off the walls Rick, brown nosing into matters that doesn't concern nor have an inch of knowledge about but i'll tell you this. I've seen the likes of Shapeshifters,A. Van Helden, DJ Falcon, Krafty Kuts and endless others which i can't even remember now when you were still in high school. This is irrelevant shit anyway... just trying to figure out where you're ACTUALLY going with this.
wow, quite allot of butt hurt people in here lol. Sounds like my presence in here and my charisma (well i reckon so anyway) is disturbing quite a few. Maybe i should be a quiet careful man who avoids risk and confrontation lol.
Are you upset i called you a phaggot Rick? Oh I'm sorry mayne...
Flynn why do you keep shit stirring?
perhaps try and get along with kunts instead of being a tool :/
just saying, it only makes you look/sound crap ya know
carry on
He'd need to google how not to be a cock sucker first, then probably read up (copy paste)
