Cut my foot open on a tin can, shit went like 1cm deep. 4 stitches, fun times.
Ouch.
How did the job interview went - forgot to ask you on Friday.
Yeah Xenons should be in WA by now lol.
I have another set, partially cloudy on the lens... Wont be ready to sell those for a few weeks, maybe early next year yet. Gotta make a bracket as one of the Ballasts is missing one.
Yo Grant! Did you just drive past Race pace?
Yep, then decided I'm thirsty and went grab some water.
A little Birdie told me what you were doing there :whistling:
Justin just talked to you?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
