Moshen was that you on the TV this morning explaining how the load shifted on your truck and you managed to bring down the bridge pile on??!!?
Anyway, events for next year.
Needs peoples onions, crap or even crapper?
http://www.skylinesa...scavenger-hunt/
http://www.skylinesa...5601-mt-buller/
http://www.skylinesa...85602-gor-2012/
Loool. Feel like posting a troll sale add now.
FOR SALE
R34 GTV
MODS
STANCE
114,000 k OBO
Thought I had a spun bearing... :P
Didn't think I had to mention "decent car" as one of the criteria Mohsen
Seriously, my 4 door.
Coilovers, Advans, 34 seats, plenty of spares...
Edited by Miguelone
Or he's successful in bribing the road authorities?
I agree, thats's incredibly dodgy! 'Sif the rest of us should get punished with no mercy while he gets to do what he wants. Maybe in Europe but you can bribe those cops with almost anything, and at least it's consistant. Special consideration? Grumble grumble grumble >_<
You think I'm paranoid? Wait till you meet my friend. Lulz
homygohd bro, i turned the car on and it made this noise, thought the engine was broken, then I realised it was my sick subwoofa.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
