Driving to sydney is the worst Hume roads are so shit, slightest bit of water and the road is like glass. Heaps of people parked on the side of the road because they can't see, a car slid of the road into the trees, my dads fairmont is aqua planing everywhere, and whether in Sydney is going to be like this for the next week
Hume is rubbish, instead of fixing it they dump gazillions of 'road safety' cameras.
It's rediculous. I thought melb was bad, it rains really heavily and then really sunny then rains again. Lol
Anyone used painless dent removal before?
Is it even an option for hail damaged cars or only the odd dent here and there?
Haven't used them, but I know most of them were booked out for months after the last massive hail storm
Just get the fixed panels
Done and change the removable panels.
Depends on how many there are. Its cheaper to get a panel beater to do it if there are a shutload. Ask Vu
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
