Today was rather interesting.
Went to get some food, look to my left and there's a fully grown man with a beard in a pink dress.
Righto then.....
no that was a mirror
fail aaron
Aloe Blacc is shithouse... I can't stand that f**king song
+1
Aloe what?
apparently its good for sunburns n shit
Did you know Northern Italians despise southern Italians with a passion and at one point wanted to break away, or cut Italia in half to form their own state? They view the Sicilians or Calabrese or any other Southern as bogan like since the southerners tend to be involved with mafia allot or other underground organised criminal organisations.
Southern Italians at one time in history were ruled by Moors, hence the reason Southerners tend to have more darker features and olive skins.
http://www.youtube.com/watch?v=kXjcf47y-zk
Northern Italy is very industrial and fairly wealthy. Southern Italy remains poor and undeveloped. There is much resentment in Northern Italy that their tax dollars keep getting poured into the southern part of the country, year after year, without the south developing its economy or anything changing much.
There is actually a small separatist movement in Northern Italy that has occasionally become violent. I think they were more active in the 1990s and have calmed down somewhat.
Italy has an term called mezzagiorno, it is the line that divides the north and the south. The 2 regions were culturaly, geographically, and historicaly separated in time. Southern Italy was poor and neglected, northern italy was the hub of the renaissance, art and culture and later industry. Southern italy shared a similar heritage with the southern Mediterranean culture where northern italy shared a heritage more similar to the northern europeans.
Edited by Flynnn
If you're doing career you'll have to drive a few seasons and get offers from the bigger teams if you're good.
Should be able to choose any team u want in the other modes though
Been playing GTA 4 lately, right now in fact
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
