went to exhaust place today to get some pipe for intake, they noticed i had a factory system still on (is factory but decat with varex copy twin tip) but because he recognized my old man (did exhaust for his merc) he asked me if I wanted to get a full 3" turbo back system with hi-flow cat made up and installed for $1k as "mates rates". This good deal? :laugh:
lol mates rates...my turbo back 3" was $600 with me supplying the cat and varex end muffler. Mild steel with mandrel bends. Don't bother with stainless it looks like ass after a year anyway and mild steel sounds better :P
It wont work with larger injectors.
You'll need to configure them within the PFC at a bare minimum regardless, or it will just over fuel and stall, it might not even idle.
This Birdy. It's a piece of piss to do, should be in Paul's faq
really? how does surface rust look better :P
fml. did Rev210's 5min $5 intake pipe mod and i just took my car for a little drive and it drove like shit. held boost fine but didnt go. before mod it went fine. HELP!!!!!
took off ic piping from turbo and return flow to get better access to rubber induction pipe, unplugged and took out afm and pod, cut induction pipe and inserted 3inch diameter/12cm long mild steel pipe, placed piece of pipe that was cut off back on and both side are secured with metal hose clamps, plugged in and insterted afm and pod back on, put ic piping back on.
Just some extra info: battery was disconnected when this was undertaken, Rev210 says to remove whole induction pipe but i left it in because the clamp for the plumb back recirc pipe was impossible to get off so i cut it while it was in the engine bay.
**EDIT**
Link to Rev210's guide.
http://www.skylinesaustralia.com/forums/topic/173019-rev210s-5min-5-intake-pipe-mod-for-your-stageaskyline/page__mode__threaded__pid__4756582
Edited by JDMKiD__/ⓞⓞ-33
Any wastelanders going to the photoshoot meet/cruise tonight?
I might head down for a bit
just around the corner from my house saw mr.P pulling over some Mitsubishi and searching his car! His partner greesed me off as i drove past. Afraid to leave house with 32 now haha
I was thinking of going down and getting some photos.... dunno if i can be bothered though... dunno anyone whose going down either really...
Got to start somewhere. I'm sure many a people didn't know anyone at their first meet
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
