Clearly didn't read the part about it being supplied eh? :D
Gold coin donation etc for foodages i believe
Ah yeah, Adam posted it on the 2nd page, was expecting it to be said on the 1st page :laugh:
All good!
Leigh, what time does calder finish?
Dunno if I'm coming down for a squizz, kinda cbf with the R being a bouncing castle...
Anyone have Cusco Zero2 for 33/34 gtr - 10kg front and 8kg rear for sale?
Site says 'late' but i think usually 11:30?? depends if its going off. Which I think it will be because I've heard lots of advertisements for it this week on the radio.
yahoo japan
Docklands building shits all over spencer building hamish. I did the letter program for seibel in docklands.. The place is a maze
i dont doubt it man.... but my floor is a pretty nice office man :)
you mean the letters online app in profiles?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
