I tell him that too about his attitude. But to this day he hasn't been Proven wrong. His attitude reminds me of yours lol
He might pick his fights, which is the smarter thing to do if you get off on fighting people or you like waiting for your mates outside the emergency room, but I'm with dezzaray on this...these kinds of people usually end up dead, bashed or in jail because one day they pick the wrong fight, with someone who is just like them and has less to lose. Wouldn't be the first time it's happened. Fights = pain for everyone. I do everything I can to avoid them!
As much as I am a hot headed person, I agree with avoiding fights where you can.
Even if you pick them, he could be a smaller guy but all it takes is for someone to pull out a knife.
Or you could smash someone, they fall awkwardly, maybe hit their head on concrete. They pass away and then you end up in prison :/
http://www.youtube.com/watch?v=WUFSHzT2xuY
Just saw this. Love the ad :D
Haha!
Honda / Acura are shelling out big bucks for movie / tv stars, host, personalities to be in their commercials.
with flynn on the other hand
Doesn't anyone know something I can clean stains off my car seats?
Even spilt water has left black stain on seats.
GF bought me some fabric remover that's normally used on clothes, gave that a shot but that was fail and made it worse lol
shaving cream.
leave it for about 15 min. dab it off with a cloth and warm water
steam clean?
shaving cream.
Interesting...Will give it a shot on the weekend
steam clean?
Steam clean is like magic on car interiors lol
As in, there is a product called Steam clean?
If your referring to steam cleaning than I don't have a steam cleaner :(
So how does one go about getting his bike license? Pretty keen on it now
Same process as car?
Do you still need to clock up x amount of practise hours?
Go here http://hart.honda.com.au/
Call up the one closest to you and book in for a two day learner course/test. They will take care of everything including the learner permit / photo etc. All you need to bring is yourself and a packed lunch.
The minute you pass their test you can stick an L plate on a learner legal bike and go nuts riding by yourself. You have wait a minimum of 3 months before you can go for your full licence. You don't actually have to ride in these 3 months, I know a lot of people who didn't, but it's a good idea to get the practice as the full licence test will be using some bike skills (it's still pretty easy).
Once you pass that test, you can ride without an L plate. A year from getting your full licence you can get a bigger bike.
Least resourceful accountant ever...go hire one or pay a car washe cafe to do it for you lol :)
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
