I tell him that too about his attitude. But to this day he hasn't been Proven wrong. His attitude reminds me of yours lol
He might pick his fights, which is the smarter thing to do if you get off on fighting people or you like waiting for your mates outside the emergency room, but I'm with dezzaray on this...these kinds of people usually end up dead, bashed or in jail because one day they pick the wrong fight, with someone who is just like them and has less to lose. Wouldn't be the first time it's happened. Fights = pain for everyone. I do everything I can to avoid them!
As much as I am a hot headed person, I agree with avoiding fights where you can.
Even if you pick them, he could be a smaller guy but all it takes is for someone to pull out a knife.
Or you could smash someone, they fall awkwardly, maybe hit their head on concrete. They pass away and then you end up in prison :/
http://www.youtube.com/watch?v=WUFSHzT2xuY
Just saw this. Love the ad :D
Haha!
Honda / Acura are shelling out big bucks for movie / tv stars, host, personalities to be in their commercials.
with flynn on the other hand
Doesn't anyone know something I can clean stains off my car seats?
Even spilt water has left black stain on seats.
GF bought me some fabric remover that's normally used on clothes, gave that a shot but that was fail and made it worse lol
shaving cream.
leave it for about 15 min. dab it off with a cloth and warm water
steam clean?
shaving cream.
Interesting...Will give it a shot on the weekend
steam clean?
Steam clean is like magic on car interiors lol
As in, there is a product called Steam clean?
If your referring to steam cleaning than I don't have a steam cleaner :(
So how does one go about getting his bike license? Pretty keen on it now
Same process as car?
Do you still need to clock up x amount of practise hours?
Go here http://hart.honda.com.au/
Call up the one closest to you and book in for a two day learner course/test. They will take care of everything including the learner permit / photo etc. All you need to bring is yourself and a packed lunch.
The minute you pass their test you can stick an L plate on a learner legal bike and go nuts riding by yourself. You have wait a minimum of 3 months before you can go for your full licence. You don't actually have to ride in these 3 months, I know a lot of people who didn't, but it's a good idea to get the practice as the full licence test will be using some bike skills (it's still pretty easy).
Once you pass that test, you can ride without an L plate. A year from getting your full licence you can get a bigger bike.
Least resourceful accountant ever...go hire one or pay a car washe cafe to do it for you lol :)
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
