nope hence why it should be interesting lol
was supposed to do that but told em i'm only free 1 day a week etc and they let me do the one day deal
There are after hour multi day courses available that can be spread apart for convenience.
Up to you if you think an extra couple of days will be useful.
Full time work - Day 1. On time, stayed awake all day. Great success
I'll give you 3 months before you become a zombie and a slave to the system...working jobs that you hate...for that shit you don't need...it's too bad...the world is based on greed...
Welcome to the rest of your life
Its good earning the money, but sad when you realize.. fark.. this is it. this is life. lol
would be better working 4 days 3 day weekend.. should be the standard imo. ;D
You'd only use it on a hot day or a cold day when not raining.
I want one, where can you get it from?
The only problem I can see with that is there is no Parker. :S
http://www.rhdjapan.com/silk-road-section-headlight-intake-kit-r32-15821
It has parker, i think its the ring around the main driving light.
fml, high pressure sprayed my car and paint flaked off the windscreen wipers which i painted not long ago ~_~
Might have to get them powdercoated or something...
Or learn to paint?
Just sprayed it with black spraycan paint, but its coming off. What i do wrong? :/
Lightly sand back, spray with primer, wet sand the primer, prepsol the surface and then spray with paint. Success! Also...you can use a trigger hose these days :)
This...used to work 4 days a week and it was the best balance between work and leisure. Was so much happier overall with the extra day, and got so much extra stuff done too :(
The money difference isn't that bad either...just that most jobs/careers don't work with only 4 days a week :(
Lightly sand back, spray with primer, wet sand primer, spray with paint. Success! Also...you can use a trigger hose these days :)
i did sand back to metal, primer and spray paint...guess i missed out on the wet sand primer..le' fu~
Also do very light coats of paint and wait for each little spray to dry...even if it takes you 15 minutes to paint them...that way you create layers to reinforce each other rather than just one layer of paint that will flake off all at once. Also prevents runs.
Spray at room temperatures and not in direct sunlight or too far away, otherwise the paint dries before it hits the part you're spraying.
Painting takes a long time to master. I even know how to do it and I still can't do it properly lol.
bah, i'll give it another shot when it all flakes off. Dont have the patience for it haha
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
