By the way, did I ever show you guys the bike I built when I was living in the UK? It started out as a shitty old red italian road bike frame, and I powdercoated it and built it up from there, here it is:
The locals got a real kick out of seeing an aussie riding a bike with a tartan seat in edinburgh.
This bike is now at home with me in Aus, and I don't think i'll ever sell it. Too many memories of riding to work alongside double decker buses etc.
:P
The hipster bike is so awesome to ride because it's so simple. No gears, no bullshit. The GT on the other hand, has 27 gears and hydraulic disc brakes and shit, it's crazy.
Edited by Astro Bear
yeh just like he has a girlfriend..
shut up man its not full on. she has school tomoz.
you just went up a notch in my book...
that puts you at two
seriously.
the only good thing was the red p plater in a prado trying to turn a 90 degree corner at like 60 kays and getting up on 2 wheels LOL
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
